2002 Ford Explorer Will not start
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
MR4526
If I drive my vehicle for lets say 45 minutes on the highway. Stop at a gas station. Turn the mortor off. 5 to 10 minutes try and restart it. It will start for 1-3 seconds and die like my old truck would when a carburator would flood. Try starting it again and will not start just like again a flooded carburator use to. I have to wait 30 to 40 don't start it and then try again. Its runs fine. Last night for the 20th time in 8 months it didn't start for over 2 hrs. I took it to a local dealer and they couldn't find anything. Is there records of this happening to other vehicles.
Mar 28, 2008 at 3:11 AM
2CARPRO JACK
  • 11,533 POSTS
We need to know what is missing when it wont start. Fuel pressure, spark or injector pulse. This will help figure it out. is the check engine light on?, if so have the PCM scanned for codes
Dec 29, 2020 at 4:04 AM
MR4526
[quote:d7d471e810="2CarPro Jack"]We need to know what is missing when it wont start. Fuel pressure, spark or injector pulse. This will help figure it out. is the check engine light on?, if so have the PCM scanned for codes[/quote:d7d471e810]
When this occurs, I'm without tools or when taken to dealer everything checked out ok. I've thought that it might be fuel pump hot or maybe fuel filter but was lookin to see if Exployers had a history of this.
2CARPRO JACK
  • 11,533 POSTS
Have seen them lose ignition modules, fuel pumps and other electric parts and sensors. This is why we need to know what is missing at that time
MR4526
[quote:828165b846="2CarPro Jack"]Have seen them lose ignition modules, fuel pumps and other electric parts and sensors. This is why we need to know what is missing at that time[/quote:828165b846]
The only other thing tried so far. Took off hose from air filter to breather and sprayed carb. cleaner inside. Truck started and ran until cleaner fluid was used and died again.
2CARPRO JACK
  • 11,533 POSTS
Definitly fuel related, does it die like it is running out of gas, or just shut down? I would check for the injector pulse, just to be sure, if it has it, I would do a fuel pump/fuel pump relay. But it does sound like a fuel pump
