2002 Ford Explorer warm air
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOHN CERVASIO
I have two vents that are cold on the drivers side.The other vents are blowing warm air.Want to know if it needs a charge to fix the problem.
Aug 31, 2009 at 4:35 AM
  • 110,251 POSTS
The air's direction is determined by vacuum operated vent doors. I would start by checking for vacuum leaks under the dash and the hood.
Sep 1, 2009 at 6:44 AM
