Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Climate Control
Air Conditioner
Not Working
2002 Ford Explorer warm air
2002 FORD EXPLORER
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOHN CERVASIO
MEMBER
1 POST
I have two vents that are cold on the drivers side.The other vents are blowing warm air.Want to know if it needs a charge to fix the problem.
Aug 31, 2009 at 4:35 AM
Experienced Mechanic
The air's direction is determined by vacuum operated vent doors. I would start by checking for vacuum leaks under the dash and the hood.
Sep 1, 2009 at 6:44 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
