2002 Ford Explorer Upper ball joint replacement
102,000 MILES • 4 CYL • 2WD • AUTOMATIC
JUNKHEAD
I have a 2002 Explorer Eddie Bauer 2WD 4.0.
What is your opinion on replacing the front upper ball joints. Some say you can press them out, some say replace the entire upper control arm. However all the auto parts stores tell me they dont carry nor can they obtian the upper control arm, and that the uppers can be pressed in and out on this model ie; the 4/door, but the 2/door sport model needs the whole arm. Im a little confused on this matter.
I have ordered Moog ball joints and Rancho shocks, I intend to attempt this repaire soon, I have a ball joint press, being that I have done this before on a Ranger...what is your opinion?
Feb 8, 2009 at 8:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
On these models, the upper ball joint is not replaceable. If defective, replace the arm.
If you would like replacement procedures for replacing your upper arm just let me know..
Thanks for using 2CarPros.com!
Feb 8, 2009 at 8:39 AM
