2002 Ford Explorer Uneven brake wear
102,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROD_KERN
When replacing the brake pads, I discovered that the rear driver's side pads were completely worn. The 3 other axles showed normal wear. I have noticed a strange smell @ that axle a few times. Do you have any ideas?
Apr 26, 2009 at 2:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Any brake fluid loss noticed? Inspect wheel cylinder to see if it is leaking onto that wheel causing brakes to lock up.
Apr 26, 2009 at 4:07 PM
