2002 Ford Explorer turn signal problem
150,100 MILES • 6 CYL • 2WD • AUTOMATIC
STACEYJOU
My turn signals stopped working. The flashers work fine. I have replaced the turn signal switch to no avail. Could my ignition switch or my key tumbler be causing this problem? My key tumbler is a little bit stripped out.
Oct 6, 2010 at 1:14 AM
  • 110,248 POSTS
The tumbler has nothing to do with it. If you had other electrical problems, I would question the ignition switch.
Does the signal light come on and not flash?
Oct 6, 2010 at 2:28 AM
