2002 Ford Explorer TURN SIGNAL
DPLENTL
Electrical problem
2002 Ford Explorer 6 cyl Two Wheel Drive Automatic
MY RIGHT REAR BLINKER DOESN'T WORK, BUT THE REST OF THE BLINKERS DO. I HAVE CHANGED THE BULB, SOCKET, AND TURN SIGNAL SWITCH ON THE STEERING COLUMN, AND IT STILL WONT WORK. WHEN I REPLACE BULB IT WILL ONLY WORK FOR A FEW SECONDS. PLEASE HELP !!!!!!!!!!!!!!!!!!!
Dec 15, 2009 at 4:16 AM
  • 110,251 POSTS
When you say when you replace the bulb, it only works for a few seconds. Have you ever tried using a test light to see if there is power to the socket? Also, have you tried replacing the signal flasher?
Dec 18, 2009 at 5:40 PM
