2002 Ford Explorer Transmission Codes !!!!!
155,000 MILES • V8 • 4WD • AUTOMATIC
KNAPP023
[img:d42210e2e5]http://www.2carpros.com/forum/automotive_pictures/312491_3caa_3_2.jpg[/img:d42210e2e5][img:d42210e2e5]http://www.2carpros.com/forum/automotive_pictures/312491_45d3_3_1.jpg[/img:d42210e2e5][img:d42210e2e5]http://www.2carpros.com/forum/automotive_pictures/312491_326b_3_1.jpg[/img:d42210e2e5]
Okay i bought this truck yesterday for $2000 bucks with known tranny problems. The guy i bought i from says he put his computer on it and got these codes; "P1700 which is Trans Intermediate Fault and P0745 which is Trans pressure control solenoid".
My questions:
What do these codes mean?? Can this unit be repaired?? Should i rebuild this unit or put in a used unit?? I found a used tranny locally for $750 with 54000 miles on it.
Any help is appreciated. Thanks in advance.
Seth Knapp
Feb 4, 2009 at 5:35 AM
2CARPRO JACK
  • 11,533 POSTS
155k on a Ford trans, it is probably done.The control solenoid is inside the trans and will cause it to burn up if not working properly.A low mileage used unit would probably be a good idea. Be sure to flush or replace the trans cooler before installing new one
Feb 4, 2009 at 11:44 PM
KNAPP023
Thanks for the response. Would i be better off having it rebuilt?? If i went that route i would get a warranty. Thanks.
Feb 4, 2009 at 11:49 PM
2CARPRO JACK
  • 11,533 POSTS
If you ae into spending the money, that would definitly be the way to go
Feb 4, 2009 at 11:56 PM
KNAPP023
What do you think a rebuild like that might cost??
Feb 5, 2009 at 2:07 AM
2CARPRO JACK
  • 11,533 POSTS
Probably gonna be a couple thousand. Call around for estimates is your best bet.
Feb 5, 2009 at 2:10 AM
