2002 Ford Explorer transfer case
LADYWRENCH
Transmission problem
2002 Ford Explorer 6 cyl All Wheel Drive Automatic
where does the transfer case read its front and rear speed sensors from? It has traction control. my 4x4 high light flashes on the dash. there are no sensors on the t-case. so, i don't have wires to connect to the speed sensors at the t-case harness.
Aug 24, 2009 at 10:50 PM
BILLYMAC
  • 2,204 POSTS
Hi, when you push the button the light comes on with the switch.
however as far as traction control it gets this reading from the abs sensors.
most likely the prob you have is a prob in the 4x4 switch and not the abs sensors. good luck billymac
Aug 25, 2009 at 10:01 AM
