2002 Ford Explorer transfer case
MACMURDO3
  • 2002 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 138,000 MILES
Feels like the front end starts to bind up when turning left or right. Trying to find out how to check transfer case fluid and how to fill.
Tuesday, May 18th, 2010 AT 11:28 AM
  • 109,885 POSTS
You will need a 3/8" drive ratchet. THere are two plugs on the back of the case. One is lower than the other. The lower one is a drain. The higher one is the level check. Remove the upper one and the fluid level should be at the bottom of the threads where the plug comes out. That is full. The same hole is where you fill it from. Here is a picture. You can see the two plugs where the ratchet goes to loosten and tighten the plug.
https://www.2carpros.com/forum/automotive_pictures/249084_0201_04zFord_Explorer_Sport_TracTransfer_Case_1.jpg
The drain is the lower left and the fill and check is about half way up on the right.
Tuesday, May 18th, 2010 AT 8:39 PM
