Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Drivetrain
Transfer Case
Fluid
1997 Ford Explorer transfer case fluid
1997 FORD EXPLORER
93,800 MILES • 6 CYL • 4WD • AUTOMATIC
JUSTINF89
MEMBER
I was wondering if the transfer case takes mercon V atf like the transmission? My 4wd options are 4wd auto, high, and low. Thanks.
Apr 16, 2010 at 7:59 AM
Experienced Mechanic
It takes Mercon (R) ATF
Apr 16, 2010 at 9:13 AM
JUSTINF89
MEMBER
mercon R? Does mercon V supersede R? I'm about to put mercon v in the transmission and I'll probably have some left over. Thanks.
Apr 16, 2010 at 9:40 AM
Dunno if it supersede R this is what I got at this present time with Mit1 ondemand5.com
Apr 16, 2010 at 12:04 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
