2002 Ford Explorer tires
TOMAMY2003
Tires and Wheels problem
2002 Ford Explorer 6 cyl All Wheel Drive Automatic
do you have to replace all four tires on this truck at the same time, and what will happen if you only replace two
Jul 22, 2008 at 8:27 AM
2CARPRO JACK
  • 11,533 POSTS
You should be safe only doing two as long as they are the exact same size as the remaining two. Personally, I would put the new ones up front and the best of what is left on the rear.
Jul 22, 2008 at 8:35 AM
