when turning dial from cold to warm the vent makes a clicking noise as if it is trying to make the switch but stays running cool .
Apr 17, 2010 at 8:54 AM
✓Experienced Mechanic
I believe you are hearing the blend door. It's what determines if you get heat or AC. HAve that checked. Chance sare there is a problem with the linkage.
