2002 Ford Explorer shifting
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIVART.4
my transmission is having trouble shifting in the lower gears. As it hesitates to shift in the lower gears the rmp rise to 3500 and as I first let off the gas pedal and then tap it, it will shift (as this happens the over drive light comes on and off very briefly). Is this a sensor problem and if so is it expensive?
Dec 1, 2009 at 6:06 AM
  • 110,248 POSTS
It could be a shift solenoid. Since the light has come on, you may want to have the computer scanned. Most parts stores will do it for free.
If it is a shift solenoid, they are not too expensive.
LEt me know if you have other questions.
Dec 2, 2009 at 3:00 PM
