2002 Ford Explorer Replacing rear brake pads!!!
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
GEO325
Would someone be able to tell me how to replace rear brake pads or let me know if there is online diagrams that go through the steps. Any help would be greatly appreciated--Thank you.
Jan 7, 2008 at 7:11 AM
MASTERTECHTIM
  • 4,750 POSTS
very easy do it yourself job. remove rear wheels, remove 2 bolts that hold the brake caliper on. gently push the piston inward and pull off caliper. using a big pair of pliers completely press the piston in. replace your pads just like they come off. reinstall the caliper and gently pump the brake pedal. thats it.
Dec 26, 2020 at 6:28 AM
