2002 Ford Explorer Rear Window Regulator
NIUPT2K
Electrical problem
2002 Ford Explorer V8 Four Wheel Drive Automatic
I have the rear right window disassembled following a window that wouldn't return to the upward position. The motor runs fine. The regulator has a plastic piece that connects the regulator to the window. This is cracked. I have looked everywhere for a rear window regulator, but can only find front ones. My dealer told me that I will need a new motor and regulator, but I am unsure...Can I get a replacement regulator and attach it to the current motor, or do I need to buy the whole set up? Thanks in advance.
Eric
Dec 4, 2008 at 9:38 AM
DAVE H
  • 13,383 POSTS
the window motor and regulator come as a unit not seperately and cost $154.88 this is an OEM dealer part cost ??
Dec 4, 2008 at 10:00 AM
NIUPT2K
Thanks Dave H, I appreciate your info. Would I be able to install a salvaged regulator into the current motor and make the window work? If not, I will look into getting one from a dealer. Thanks again!
Dec 4, 2008 at 11:46 AM
DAVE H
  • 13,383 POSTS
i don't have seperate price listing's ... and in the manual it gives a removal procedure for both together because they must have to come out togehter ?? but in my database for work times i have times for R&R of regulator ... and R&R of motor .. so i'm guessing you must be able to seperate them once off the vehicle ?? your best bet would be to try a salvage yard and remove it to see if they do in fact seperate once off vehicle .. if they don't you could still replace with salvaged part .. ???
Dec 4, 2008 at 11:59 AM
