Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Body
Rear Window
Motor
2002 Ford Explorer REAR WINDOW MOTOR/REGULATOR REPLACEMENT
2002 FORD EXPLORER
137,000 MILES • 6 CYL • 4WD • AUTOMATIC
KWSMITH8
MEMBER
1 POST
CAN SOMEONE TELL ME HOW TO GET THE RIVET OR RETAINER SCREW OUT OF THE WINDOR BRACE SO I CAN ATTACH THE NEW MOTOR/REGULATOR ASSEMBLY
Feb 10, 2010 at 12:03 PM
BLUELIGHTNIN6
Experienced Mechanic
if your vehicle has rivet instead of bolt you will have to drill the old rivet out first..
Feb 10, 2010 at 1:40 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
