2002 Ford Explorer Rear Spring
2002 FORD EXPLORER
170 MILES • 6 CYL • 4WD • AUTOMATIC
BOBBYOSBORNE
I have a broken rear spring, how do I change it. Do I need to change both if only one is broken? Should I Change both shocks?
May 23, 2010 at 11:05 AM
  • 110,244 POSTS
Are you refering to a leak spring? If so, I would recommend replacing both. Also, check the condition of the shackle that attaches them to the frame. They have a history of rusting.
As far as the shocks, if they were good before the spring broke, they should be fine.
May 25, 2010 at 11:38 PM
CARY83
I just changed my back struts and found that both my springs were broken. So I think it best you replace both. You have to take your control arm bolt off and there are two others you have to take off to.
Jun 1, 2010 at 2:48 AM
  • 110,244 POSTS
Also, make sure to check the shackle. Again, they have a history of rusting and breaking.
Jun 1, 2010 at 3:36 AM
