2002 Ford Explorer rear end noise
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN CERMAK
The noise I am hearing from my rear axle started around 70,000 miles and is getting louder and louder. It sounds like a bearing, whrrrring that gets higher pitch with speed. Is not effected by braking or acceleration. My dealers service adviser, Pete, says I need a new rear axle, $1200 part plus labor. He says it is an independent rear axle. I can't imagine I need an entirely new axle, maybe axle bearings, maybe differential bearings etc. If it has half shafts like a FWD maybe I could replace them. My U-Pull-It wants $100 for an axle which is in my budget. Pete says these independent Explorer axle problems are common. Is this so? Is this something a shade tree mechanic can tackle on his own? I've replaced a few transmissions, master & wheel cylinders, radiators, etc. What can you advise a budget minded driver. Thanks for your consideration.
Nov 14, 2009 at 12:03 PM
  • 110,248 POSTS
Yes it has an independent axle. And yes, you can replace one side. My question is what parst cost 1200.00? As far as you doing it yourself, I don't see why you couldn't. I would recommend replacing the bearings with new, but if you need the axle, get a good one from a salvage yard.
Nov 17, 2009 at 7:33 AM
