Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Brakes
ABS
Wheel Speed Sensor
Location
2002 Ford Explorer Rear ABS Sensor
2002 FORD EXPLORER
194,000 MILES • 6 CYL • 4WD • AUTOMATIC
CTJMECHANIC
MEMBER
1 POST
Need to know where the rear ABS sensor is located so I can replace it.
Nov 10, 2008 at 12:39 AM
BMRFIXIT
Experienced Mechanic
If u have only one rear sensor
that would be mounted on top the rear differential in the middle
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 10, 2008 at 10:33 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
