2002 Ford Explorer Pulling out the air filter housing
90,000 MILES • V8 • 4WD • AUTOMATIC
CAVANHOR
I am trying to pull out the air filter housing (not sure if that is the correct termanology) to access a "washer fluid" hose that got disconnected. it seems as if the air filter housing should just snap out but no such luck.
What I have done is released the quick disconnects to pull the air filter out and move the air intake assembly aside. This enabled me to access the "air filter housing" that is in the way of me reaching the washer fluid lines. I don't see any nuts or bolts to unscrew...like I said, it seems like it should just unsnap.
Can someone please help. Thanks.
Craig
Jan 5, 2008 at 3:57 AM
FLEXY5
  • 512 POSTS
grab it hard and pull it upwards and towards the fender. It will seem like you are going to break it, but you shouldn't. It may help to wiggle back and forth while you are pulling. It it only held in with nubs and gromets.
Jan 5, 2008 at 12:58 PM
