2002 Ford Explorer Problem opening my hood
64,000 MILES • V8 • 4WD • AUTOMATIC
DOBEY217
My hood isn't popping open when I pull on the handle. I think that it is just a problem with the cable between the release and the the latch. Roughly how much would this cost to fix and is this a common problem among explorers?
Oct 25, 2010 at 2:14 PM
  • 110,248 POSTS
Try this first... have a helper pull the release while you tap on the hood over the latch assembly. Somethimes they need luberication and don't work properly.
Oct 26, 2010 at 1:47 PM
