Low pressure oil
67,000 MILES • 6 CYL • 4WD • AUTOMATIC
ADNAN_ALMAHROUQ
low pressure oil, can you tell me where the oil pressure sensor is?
Mar 18, 2008 at 11:19 PM
  • 75,988 POSTS
Syre the oil pressure sender is near the oil filter and lower radiator hose, is the sensor is okay I would remove the oil pan to see if any sludge is blocking the oil pump pick up. Also here is a guide to help us see hats going on with the location of the oil pressure sensor in the images below.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Check out the images (below). Let us know how it goes
Mar 18, 2008 at 11:39 PM
