2002 Ford Explorer Possible Transmission issue???
94,000 MILES • 6 CYL • 4WD • AUTOMATIC
RUFFRYDERRD87
I am having problems with my overdrive light, it keeps flashing on and off. It recently started shimmying at multiple speeds and would stop once I let off the accelerator. Happened at exactly 40 mph and again at about 60 mph. It doesn't do that anymore and now the overdrive light will flash after driving for about 5 minutes. Not sure what the issue is, any ideas? Thanks in advance for your help!
Mar 27, 2008 at 2:08 PM
SERVICE WRITER
  • 9,123 POSTS
You need to have the codes read in the computer.
There will be a code that I can help you further with once we know it. Maybe a combination of problem or not. Possible torque converters, solenoids packs, shift solenoid..
Mar 27, 2008 at 2:25 PM
