2002 Ford Explorer Passenger driver side power window
44,000 MILES • V8 • 2WD • AUTOMATIC
AMFMARTIN
I can hear the motor going full cycle up and down and then stop but the window is still down. How do I take the panel off to realign this problem. I have removed one screw on the lower left side and removed to door handle panel. That all I can do at this point.
Mar 9, 2008 at 3:24 AM
MERLIN2021
  • 17,250 POSTS
You need to buy a trim tool and get under each plastic clip and pop them out as you go along, if you try to pull the panel off, the holding sections will break off...
Mar 9, 2008 at 3:28 AM
