2002 Ford Explorer Oil light comes on along with High tempe
2002 FORD EXPLORER
139,900 MILES • 4 CYL • 4WD • MANUAL
SYDUHART
Hi guys:
My oil pressure light comes on stating that my oil pressure is low, along with a high temperture light. I have changed the oil, and there is no noise coming from the engine such as knocking or ticking.
My question to you is do you think it is possibly a bad oil sensor, and if so, can it wait a few days before fixing it?
Thanks,
Sy
Jun 5, 2008 at 10:03 PM
LEGITIMATE007
  • 5,121 POSTS
sure it could be, I would bring it to autozone and have it scanned for trouble codes to be sure, but firstly, just top off all of your fluids for an extra safety measure. and also check your engine coolant temp sensor and thermostat. you should be ok, but address it asap
Jun 5, 2008 at 10:17 PM
SYDUHART
Thank you so much. I will definitely take it to Auto Zone to have it diagnosed. I apprieciate your insight. Once Again, Thank you.
[quote:dbf84bd6a3="legitimate007"]sure it could be, I would bring it to autozone and have it scanned for trouble codes to be sure, but firstly, just top off all of your fluids for an extra safety measure. and also check your engine coolant temp sensor and thermostat. you should be ok, but address it asap[/quote:dbf84bd6a3]
Jun 5, 2008 at 10:51 PM
LEGITIMATE007
  • 5,121 POSTS
Hey,,,, thats what we are here for. and you come back anytime you need to
Jun 6, 2008 at 5:13 AM
