2002 Ford Explorer ODB Code p0735
10,100 MILES • 6 CYL • 4WD • AUTOMATIC
MBELLAS
What canit (should it ) cost to repair a OBD Code P0735?
May 22, 2010 at 4:30 PM
  • 31,937 POSTS
P0735 Gear 5 Incorrect ratio
This is just to hard to say as further diagnosis will be required to find the actual reason for this fault, get this transmission tested by a trans specialist and get a report and quote on this problem, post the quote here for me to check over.
mark (mhpautos)
May 22, 2010 at 5:28 PM
MBELLAS
mhpautos, thanx for your reply.
The quote from AAMCO is:
1 Banner Kit(b); 1 Filter (b); Band intermediate Flex & Overdrive; Band Intermediate Flex & Overdrive (yes, it was written twice in the Quote); 12.6 Fluid (b); 7 Labor (rr) (b); 9 Labor (r) (b); 1 **labor Shop Supplies.
He also suggested they will probably need a Torque Converter but didn't quote it yet.
I, of course, don't want to pay for something I don't need. Or if I do need it not be overcharged.
Thanx
May 23, 2010 at 1:17 AM
  • 31,937 POSTS
Not sure what you mean by (b) with items
mark.
May 23, 2010 at 3:41 PM
MBELLAS
I do not know what (b) means either. It is how AAMCO gave me their quote. Can you give me an "estimate" regardless of the (b)?
Thanx
May 24, 2010 at 1:30 AM
