Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Oxygen Sensor
Replace/Remove
2002 Ford Explorer o2 SENSOR
2002 FORD EXPLORER
83,000 MILES • 6 CYL • 4WD • AUTOMATIC
YANKO540
MEMBER
1 POST
When you replace the the 02 sensor must it be OEM or can any be used ?
Apr 19, 2010 at 12:59 PM
Experienced Mechanic
If it is good, you can use a used one.
Apr 23, 2010 at 5:18 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
