2002 ford sport track. vehicle has been running fine. last week turning the ignition to the on position i noticed that i did not hear the fuel pump prime. I turned the key to the start position but, it would only crank. pulled the key out & turned it again to the on position, the fuel pump primed. cranked the motor & it started ok. been driving ok!
I drove the car to work & home last night, every thing ok. Went to start it today, i turned the key to the on position did not hear the fuel pump prime. I cranked the engine but would not start, tried several times, not even a sputter. shot some starting fluid into the intake, still would only crank, not even a sputter.. no smell of flooding. i did not check for spark yet. the outside weather is a high of +10.
last week the weather was also cold on the day that I first had a problem. Thinking about the fuel pump relay? or the securilock antitheft. I did try a spare key, no luck!
Thanks, Al
Thanks, Al
Jan 2, 2010 at 8:40 PM
