2002 Ford Explorer Miss Fire in 3
91,000 MILES • 4 CYL • 4WD • AUTOMATIC
SOUTHERNGENTMINT
Hello, I have a truck that says it has a miss fire in cylinder 3, I have put new spark plugs, new wires, new ignition coil, and a new egr valve, and had new fuel ignition put on, but the problem continues, what else could it be, my truck idles hard when going about 50 to 60 mph, and the whole egine shakes the whole time its running.
Jul 24, 2008 at 12:52 PM
BMRFIXIT
  • 19,053 POSTS
new coil did u check if its firing
new injector did u check for pulse
if u have an open wire then the new or old part will not do it job
Jul 24, 2008 at 1:07 PM
