2002 Ford Explorer leaks
175,000 MILES • 6 CYL • FWD • AUTOMATIC
RLILHOOVA
i have a 2002 explore and it leaks from where the transmission and the engine meet. and i wanted to know what seal that was so i can replace it thank you
Feb 2, 2010 at 9:50 AM
  • 110,248 POSTS
If it leaking trans fluid there, it's the front seal. You need to remove the transmission to access it. It's labor intense, but the part is cheap.
Feb 5, 2010 at 2:31 AM
