2002 Ford Explorer leaking tranny
141,900 MILES • 6 CYL • 4WD • AUTOMATIC
LYNNBOY021
here is the thing i was reading posts and stuff and they said when the tranny gets hot it leaks but in my case when i start up the truck it does not leak but after like 5 mins it starts leaking but the tranny fluid is cold not warm or hot then when i turn off the truck it stops leaking. so i bought a new pump and a new converter so maybe one of them is no good? the tranny has no problems shifting or anything truck only has 141,000 but it was a companey truck like a fleet truck and i bout it at action so dont know much about truck.. not making a sad story or anything but i have 3 babies and a wife stuff to pay and i dont have a job right now so its hard to buy parts (thanks god for ebay) i am a mechanic but not a tranny pro or tech i did rebuild my 700r4 tranny and it was really easy. i have alldata pro and i seen that ford has a tsb about the 5r55w tranny leaking from where mine is leaking but it says..... Article No.
03-5-7
03/17/03
TRANSMISSION - 5R55W - FLUID LEAK FROM THE
CONVERTER HOUSING AREA
FORD:
2002 EXPLORER
MERCURY:
2002 MOUNTAINEER
Article 01-11-05 is being republished in its entirely to update the Service Procedure.
ISSUE
This TSB supersedes 01-11-05 and is being reprinted to further clarify the diagnosis and repair procedures. Fluid leaks in the converter housing area must be diagnosed using the Leak Diagnostic Procedures found in the Workshop Manual.
ACTION
Fluid found to be in the converter housing area is not due to vent components but may be due to other transmission issues, i.e., transmission overheat, seal leaks etc. The vent service kit that was referenced in a previous TSB will no longer be available for purchase or usage as a repair component. If fluid is coming from the converter housing area follow normal diagnosis for fluid leaks as found in the Workshop Manual Section 307-01. If repairs are required, follow normal Workshop Manual procedures using the correct service part(s) as listed in your parts catalog.
OTHER APPLICABLE ARTICLES: NONE
SUPERSEDES: 01-11-05
WARRANTY STATUS: INFORMATION ONLY
OASIS CODES: 504000, 510000
but i dont have a workshop manual to look at section 307-01...thanks and i am so so sorry about a long post... you guys rock
Feb 15, 2010 at 11:54 AM
DOCFIXIT
  • 18,828 POSTS
Hi
What your describing is a front seal leak. Was new pump complete with new bushing and seal? was convertor neck free of groves and nicks? Excess play in crankshaft can cause leak while running.
Let me know
Thanks for donate
Worrkshop Manual has to do with convertor leak tasting, end play, ons way clutch check
Feb 16, 2010 at 12:45 AM
LYNNBOY021
all new pump and converter. i cut the vent tube and its leaking from the vent tube so maybe the cooler is cloged?
Feb 16, 2010 at 11:24 AM
DOCFIXIT
  • 18,828 POSTS
That is something need to check could be holding pressure in trans causing fluid to come out vent.
Feb 17, 2010 at 2:19 AM
