2002 Ford Explorer It won't start
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
123ERICA
Starter replaced, new battery, and 3 plugs replaced. Still won't start. What to do???
May 25, 2010 at 6:45 AM
  • 75,988 POSTS
If its cranking ove and will not start do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
No crank at all-could be the starter relay, transmission range switch and ignition switch
May 25, 2010 at 11:48 AM
123ERICA
I have a new battery, a new starter, and 3 new plugs. It is not turning over [lights up, though] and it won't start! I am at my wits end!
May 27, 2010 at 6:47 AM
  • 75,988 POSTS
Is it cranking over and will not start or just won't crank over/nothing happens when you hit the key
May 27, 2010 at 9:41 AM
