2002 Ford Explorer hot and cold
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
AIRIC74
  • 12 POSTS
AC was recharged and I get cold air on the drivers side and warm on the passenger side.When I close the vent closest to the passenger door you hear the wind howl through it.I believe it is the blend door but I can not find any place that shows me where it is in the dash.
Jun 25, 2010 at 1:22 PM
BLACKOP555
  • 10,386 POSTS
is vehicle equipped with auto air or manual temp and speed control?
next does it have a separate control for passanger and driver side
Jun 26, 2010 at 1:13 PM
AIRIC74
  • 12 POSTS
The truck has manuel ac and dos not have seperate controls for drivers and passengers side,but has rear ac.I have no problems yet with the rear ac
Jun 27, 2010 at 5:13 AM
BLACKOP555
  • 10,386 POSTS
chances are your blend door inside the ducts are sticking or the motor is inoperative
Jun 28, 2010 at 4:43 AM
AIRIC74
  • 12 POSTS
I had the dash removed where the radio is and both doors were closed.Is there another door further back towards the firewall?If so where?
Jun 28, 2010 at 1:11 PM
BLACKOP555
  • 10,386 POSTS
there is the blend doors further back. i belive that ones your talking about right now is the mode doors that select where the air goes through
Jun 29, 2010 at 5:15 PM
