2002 Ford Explorer Hesitation
119,000 MILES • 6 CYL • 4WD • AUTOMATIC
HOP_SING88
The check engine light came on and was told the egr vavle was bad so i replaced the egr valve but the check engine light is still on my explorer and it also has a constant hesitation when you hold the gas pedal in one spot. Any ideas?
Jan 20, 2010 at 10:58 AM
  • 75,988 POSTS
Have the computer scanned for code/s-you have a problem within the engine manangement system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Jan 20, 2010 at 11:08 AM
