2002 Ford Explorer HEATER WILL NOT WORK
50,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEFF HORN
THE AIRCONDITIONING WORKS FINE, BUT WHEN I SWITCH TO HEAT,IT MAKES A CLICKING SOUND AND THE AIR COMING OUT OF THE VENTS STAYS COLD LIKE THE AIR CONDITIONING IS STILL ON.
Oct 15, 2009 at 11:14 AM
  • 110,248 POSTS
You need to have the "blend door" repaired. It is responsible for allowing air to pass over the heater core and heat the air. If it is clicking, it either is stuck or damaged.
Oct 26, 2009 at 1:47 AM
