2002 Ford Explorer heater does not work
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALONNA E
When I turn on my heater it blows out cold air instead of warm air. The heater control Valve is working. The hose going into the heater coil is good and hot. It also has front and rear heat control and neither one of them is working. What is my problem?
Oct 23, 2009 at 11:19 AM
BMRFIXIT
  • 19,053 POSTS
Check and suspect blend door and or actuator
Oct 24, 2009 at 7:49 AM
