2002 Ford Explorer 4 cyl Four Wheel Drive Automatic
my vehicle will not fill up with gas. Will not take gas I pulled the tank out. Check all vent lines and all free and clear can blow through. What should I do next thanks
Tuesday, January 5th, 2010 AT 1:47 PM
MECHANIC
When the tank fills, air exits through the breather tube that follows along the filler tube. Did you check that? THat is the only thing that would slow the process of filling the tank.
