2002 Ford Explorer Fuel Pump
130,000 MILES • V8 • 4WD • AUTOMATIC
JAMMIE LANE
When starting vehicle anytime throughout the day for the first time, vehicle hestitaes to start. Vehicle starts after 2 or 3 times after turning the igintion key. Could this be the fuel pump not pumping enough gas?
Oct 26, 2008 at 2:29 PM
ROB2008
  • 258 POSTS
It's possible ,but I would replace the fuel filter first ,as it might be clogged.This may be a cheap fix for you .
Oct 26, 2008 at 2:43 PM
  • 75,988 POSTS
When you turn key to run -do you hear the fuel pump come On if so check the fuel pressure to confirm if its within specificatons also check the operation of the FPR-Also test the coolant temperature sensor-its job is to tell the computer to adjust fuel during initial start up-before the oxygen sensors takes over in the closed loop mode-
Oct 26, 2008 at 2:58 PM
