2002 Ford Explorer Four Wheel Drive Unresponsive
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
KFLAHERTY3
My four wheel drive won't shift into 4HI or 4LO. On snow I can make the car fishtale in what should be 4AUTO. No lights illuminate or flash on the selector switch. No noise is heard from the transfer case and no codes are recorded. The only recent repair I made was to replace the steering column. Any ideas??
Jan 4, 2010 at 5:05 AM
JESTERC
There is a 4WD control module located behind the glovebox that is frequently the cause of the problem. Check with your local auto parts supplier or dealer.
Jan 6, 2010 at 2:38 AM
