fan clutch replacement instructions please?
112,000 MILES • V8 • 4WD • AUTOMATIC
DEWIGHTB
I have had 2 fan clutches installed, and the fan still stays engaged a very long time after i start. I got a new one from ford I want to try it out.
Gene
Jul 20, 2009 at 5:04 AM
SQM
  • 6,383 POSTS
A faulty fan clutch would keep the fan engaged for extended period of time or may not engage at all.
To remove the fan clutch you will need a special fan clutch tool.
These tools are readily available at your local auto parts stores that you can "rent" to get the job done.
Here is a helpful article of how to change fan clutch:
https://www.2carpros.com/articles/fan-clutch-removal
Check out this video for some helpful tips:
https://youtu.be/N_-MLVlBHk8
I have attached the replacement procedure for your vehicle.
Jul 22, 2021 at 3:10 AM
