2002 Ford Explorer Engine won't turn over
2002FORDCLUNKER
Electrical problem
2002 Ford Explorer 6 cyl Two Wheel Drive Automatic
I just replaced my transmission and engine with used parts now it won't crank. The started checkout good and the battery is new. One thing I've noticed is my theft light is not flashing on the dash panel.
Oct 23, 2009 at 10:27 AM
BMRFIXIT
  • 19,053 POSTS
Not flashing is good
flashing you have a security issue
do check for codes
did you check N/P switch on tranny
and its wiring
check starter wire too
can you jump start the starter ?
Oct 24, 2009 at 7:52 AM
