2002 Ford Explorer Engine Missing
295,000 MILES • 6 CYL • 4WD • AUTOMATIC
EDELABRETONNE
At about 3000 RPM the engine starts miussing. Is there a govener on this vehicle? Or does it have a problem.
Jan 21, 2010 at 2:26 PM
  • 75,988 POSTS
An engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 21, 2010 at 3:20 PM
