2002 Ford Explorer Emission Codes
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
WENDY J
I have a 2002 Ford Explorer that has failed emissions. the codes that come up are P0141, P0442, and P1401. Seems to be running okay except once in a while it loses power at take off and then it comes right back. Also, I noticed that when it's cold outside the car will run hot after warming up. Once the heater is turned on, it goes back to normal. I need to get these codes fixed and don't really have the $$ to go to the dealer. Is this an easy fix, and can i buy these parts at a part store or just the dealer?
Dec 28, 2007 at 6:44 AM
BLACKOP555
  • 10,386 POSTS
P0141 means bank one sensor two is bad, this usually means you have a bad o2 sensor or bad catalytic converter.
P0442 means Evaporative Emission Control System Leak Detected (small leak) and you should in turn change the fuel cap with a DEALER OEM PRODUCT. also check the vaccum line going from the tank to the charcoal canister. you may also need a new charcoal canister.
P1401 means DPF EGR sensor circuit was showing high voltage. It is a common failure for fords is the dpfe sensor it can cause overheating also and failing a emmision test due to NOx
Dec 28, 2007 at 12:20 PM
