2002 Ford Explorer electric windows
111,000 MILES • V8 • 4WD • AUTOMATIC
MECOOK55
where is the window regulator on front passenger side
Feb 14, 2010 at 1:18 AM
MATHIASO
  • 1,209 POSTS
Remove the front door trim panel as follows: 1. Remove the front door handle bezel. 2. Remove the front door window/lock control switch bezel. 3. Disconnect the window/lock control switch electrical connectors. 4. Remove the 3 front door trim panel screws. CAUTION To avoid damaging the trim panel, do not pull directly outward to carry out this step. # Lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips. # Remove the exterior mirror control switch from the front door trim panel. # Remove the front door speaker. # Remove the water shield. # Disconnect the front door window regulator motor electrical connector. # Drill a 13 mm (0.52 in) hole using the locator in the door sheet metal as a guide. Remove the bolts and the front door window regulator motor.
https://images.2carpros.com/forum/automotive_pictures/46384_0996b43f80202aa1_1.jpg
You can also see the 3 bolts that hold the regulator in this pic.
https://images.2carpros.com/forum/automotive_pictures/46384_window_regulator_1.jpg
(I'm sending those pics to your email)
Feb 14, 2010 at 2:15 AM
