2002 Ford Explorer driver window motor and regulator replac
2002 FORD EXPLORER
63,000 MILES • 6 CYL • 4WD • AUTOMATIC
HARRY KING
procedure for regulator replacement with the window stuck in the up postion
Jan 7, 2008 at 11:32 AM
2CARPRO JACK
  • 11,533 POSTS
According to my software the regulator is bolted to the door.You will have to remove door panel,inside glass weatherstrip,lock rod at latch assembly,then carefully unbolt reg to lower it enough to gain access to whatever is holding the glass to the reg (bolts or rivets).put glass in full up position and secure it( blue painters tape over the top of the door frame) Seperate the two and remove reg from door.
Jan 7, 2008 at 11:48 PM
