2002 Ford Explorer cylinder head
78,000 MILES • V8 • 4WD • AUTOMATIC
MYSPACE
do to a sparkplug that has shot out i had that repaired but there seems to still be a hole somewhere around that sparkplug. they say i need to replace the cylinder head. lets say i never replace that cylinder head at all? what can happen to the engine is it still driveable?
Dec 4, 2008 at 3:59 AM
DAVE H
  • 13,383 POSTS
it all depends on what size hole your talking about .. whichever size of hole .. your going to be losing compression on that cylinder .. the bigger the hole the less likely you will get any type of seal ... the more loss of compression .. you have also got the chance of debiris getting into the hole and causing other damage .. to piston's and ring's etc. the best thing would to replace the head .. ?? at the very least you will have driveability problems ..
Dec 4, 2008 at 4:07 AM
MYSPACE
so how much do u think that will cost when i had it looked at the first time they said 3200 is that alot or does that seem fair
Dec 4, 2008 at 4:15 AM
DAVE H
  • 13,383 POSTS
not knowing which side is broken .. i have priced right hand side which takes the longest to do .. the head is OEM dealer part with valves and camshaft included ... you may be able to get this cheaper elsewhere ??
labor =9 hrs @ $50 p/h $450-00
of course your shop may have different labor charges
head w/valves and camshaft $1,145.52
total .. $1,595.52
Dec 4, 2008 at 4:44 AM
DAVE H
  • 13,383 POSTS
sorry i priced up a V6 head ...
the V8 head cost's $824.33 incuding valves
+ $450-00 labor
total $1,274.33
Dec 4, 2008 at 4:48 AM
