2002 Ford Explorer Cruisecontrol not working
115,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHEF2B86545
I am just wondering if there is a fuse/relay for the cruise control. There is not one listed in the owners manual so i am not sure where to start to figure out what is wrong and why it is not working. Can someone help me.
Feb 25, 2009 at 10:14 AM
KEVIN12881
  • 336 POSTS
yes (maybe under hood but not sure on your make). There are several things that could keep it from working ncluding the brake switch, electric control module, control switches, and veehicle speed sensor. Check out the fues and relay along with all electric connections and get back to us
Feb 25, 2009 at 10:23 AM
CHEF2B86545
I am not sure where any of that woud be.
[quote:8c4531ee1c="kevin12881"]yes (maybe under hood but not sure on your make). There are several things that could keep it from working ncluding the brake switch, electric control module, control switches, and veehicle speed sensor. Check out the fues and relay along with all electric connections and get back to us[/quote:8c4531ee1c]
Feb 25, 2009 at 10:35 AM
KEVIN12881
  • 336 POSTS
first look under the hood for the fuse box. remove the cover and it should have lables for the fuses, check to see that the one laballed for the cruise is good. if you do not see it there, then check the fuse box inside the cab.
Feb 25, 2009 at 11:19 AM
