2002 Ford Explorer Command Center
ANDYEY
2002 Ford Explorer
The other day, my command center started displaying the Zone instead of the temperature. How do I make it go back to the way it used to be???
Thanks!
Dec 20, 2009 at 5:40 AM
RICKMAR
  • 170 POSTS
Press and hold the (Center) MODE button
until VAR appears in the display,
then release.
The display should
show the current zone number.
Press the (Center) MODE button again. The
display will flash and then return to
normal operation.
Good Luck;
Rick
Dec 20, 2009 at 11:44 AM
ANDYEY
do you mean the MODE button that resets the trip count?
Thanks!
andy
Dec 20, 2009 at 11:56 AM
RICKMAR
  • 170 POSTS
No....the middle MODE button right in the center ,
This unit is the one "overhead" between the visors. The display...tells you the outside temp..direction N.S.E.W.
There is just three buttons ...map light and ...
If you have any more questions just reply to this post...I will get right back to you.
Rick
Dec 20, 2009 at 4:38 PM
ANDYEY
Thanks Rick, but I don't have those buttons. I'm referring to the compass and temperature that are with the odometer...
Does that make sense?
Thanks!
Dec 21, 2009 at 1:52 AM
RICKMAR
  • 170 POSTS
Ooppsss...Sorry about that Andy, I was thinking of a different year.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Happy holidays;
Rick
Dec 21, 2009 at 6:15 AM
ANDYEY
Thank you Rick. There's actually no "tiny hole at the base of the mirror"...its a button on the sensor that is attached to the mirror, in case you get the same question again.
Merry Christmas and thanks for your help!
andy
Dec 21, 2009 at 9:41 AM
RICKMAR
  • 170 POSTS
I am glad it finally got worked out.
I appreciate you letting me know there's actually no "tiny hole at the base of the mirror"...and its a button on the sensor that is attached to the mirror!!
Merry Christmas Andy.
Rick
Dec 21, 2009 at 11:57 AM
