The other day, my command center started displaying the Zone instead of the temperature. How do I make it go back to the way it used to be?
Thanks!
Sunday, December 20th, 2009 AT 1:40 PM
RICKMAR
MECHANIC
Press and hold the (Center) MODE button
until VAR appears in the display,
then release.
The display should
show the current zone number.
Press the (Center) MODE button again. The
display will flash and then return to
normal operation.
Good Luck;
Rick
SPONSORED LINKS
Sunday, December 20th, 2009 AT 7:44 PM
ANDYEY
MEMBER
Do you mean the MODE button that resets the trip count?
Thanks!
Andy
Sunday, December 20th, 2009 AT 7:56 PM
RICKMAR
MECHANIC
No. The middle MODE button right in the center,
This unit is the one "overhead" between the visors. The display. Tells you the outside temp. Direction N.S.E.W.
There is just three buttons . Map light and .
If you have any more questions just reply to this post.I will get right back to you.
Rick
Monday, December 21st, 2009 AT 12:38 AM
ANDYEY
MEMBER
Thanks Rick, but I don't have those buttons. I'm referring to the compass and temperature that are with the odometer.
Does that make sense?
Thanks!
Monday, December 21st, 2009 AT 9:52 AM
RICKMAR
MECHANIC
Ooppsss...Sorry about that Andy, I was thinking of a different year.
Thank you Rick. There's actually no "tiny hole at the base of the mirror". Its a button on the sensor that is attached to the mirror, in case you get the same question again.
Merry Christmas and thanks for your help!
Andy
Monday, December 21st, 2009 AT 5:41 PM
RICKMAR
MECHANIC
I am glad it finally got worked out.
I appreciate you letting me know there's actually no "tiny hole at the base of the mirror". And its a button on the sensor that is attached to the mirror!
